06-13-2006 05:28 AM - edited 03-09-2019 03:13 PM
I upgraded the ios to 12.4. After the upgrade the interface behavior is a little diffrent. If there is no client connected to one of the fastethernet ports, the e0 interface is down. My problem is, we use this e0 interface for remote administration of the c831 over a vpn connection. So if no device is turned on in the night, I can't reach the router. Is there a solution to keep the interface up or to reach the router otherwise ?
no service pad
service password-encryption
hostname xxx
enable secret xxx
username admin password xxx
ip subnet-zero
ip domain name xxx
ip dhcp excluded-address 192.168.45.254
ip tftp source-interface Ethernet0
ip dhcp pool COUNTER
network 192.168.45.240 255.255.255.240
domain-name xxx
default-router 192.168.45.254
dns-server 10.128.128.1 10.128.128.3
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key 0 xxx address 213.xxx.xxx.xxx
crypto ipsec transform-set VPN esp-3des esp-md5-hmac
crypto map VPN 10 ipsec-isakmp
set peer 213.xxx.xxx.xxx
set transform-set VPN
match address 102
interface Ethernet0
ip address 192.168.45.254 255.255.255.240
hold-queue 100 out
no shut
interface Ethernet1
no ip address
duplex auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
no shut
interface Dialer1
ip address negotiated
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname xxx
ppp chap password 0 xxx
ip access-group 101 in
ip access-group 100 out
crypto map VPN
no cdp enable
ip nat inside source list 100 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
access-list 1 permit 10.128.128.200 0.0.0.7
access-list 1 permit 10.128.128.208 0.0.0.7
access-list 1 permit 10.128.128.216 0.0.0.3
access-list 100 permit esp host 217.91.19.71 host 213.xxx.xxx.xxx
access-list 100 permit udp host 217.91.19.71 eq isakmp host 213.xxx.xxx.xxx eq isakmp
access-list 100 permit ip 192.168.45.240 0.0.0.15 10.0.0.0 0.255.255.255
access-list 100 permit ip 192.168.45.240 0.0.0.15 192.168.0.0 0.0.255.255
access-list 101 permit udp host 213.xxx.xxx.xxx eq isakmp host 217.91.19.71 eq isakmp
access-list 101 permit esp host 213.xxx.xxx.xxx host 217.91.19.71
access-list 101 permit ip 10.0.0.0 0.255.255.255 192.168.45.240 0.0.0.15
access-list 101 permit ip 192.168.0.0 0.0.255.255 192.168.45.240 0.0.0.15
access-list 102 permit ip 192.168.45.240 0.0.0.15 10.0.0.0 0.255.255.255
access-list 102 permit ip 192.168.45.240 0.0.0.15 192.168.0.0 0.0.255.255
line con 0
login local
no modem enable
length
transport preferred all
transport output all
stopbits 1
line aux 0
login local
stopbits 1
line vty 0 4
exec-timeout 120 0
login local
length 0
transport input all
scheduler max-task-time 5000
06-13-2006 06:17 AM
Since this ethernet is a logical interface I do not know if this will work or not but try putting a 'no keepalive' under the interface configuration. I will be interested in knowing if the router even accepts this command for a logical interface as this commands is tied to the physical behavior of normal ethernet interfaces.
06-13-2006 06:37 AM
The router accepted the command and shows 'Keepalive not set' in the interface status but it did not solve the problem.
The release notes of the 12.4 ios for c831 describes the behavior of the e0 interface, which is now dependent of the fastethernet interfaces 1 trough 4.
My next idea is to create a virtual interface, which is not dependent of a physical 'up' interface fa1-4. But how would I do this ?
06-13-2006 06:42 AM
You can create a loopback interface using:
Router(config)# int loopback 0
Router(config-if)# ip address
This interface will always stay up but you have to make sure that the ip address you assign to it is router over the tunnel.
06-22-2006 11:26 AM
We had the same issue with 871's. The fix was to upgrade to 12.4.6T and use the no autostate command under the vlan internface. Not sure if this is available for the 831.
