VPN B2B link between our 3005 and a Nokia VPN concentrator at our client's site. Link has been up and solid for about 5 months. We support 4 remote servers and these are the only IPs set to cross the tunnel.
In a round-robin fashion, 1 or 2 of the IP addresses fails to ping for a few minutes or a few hours. The target host is actually still working and pingable from the other side of the tunnel. (from the other servers)
* The other IP's work fine
* Net Admin for Nokia side says no change on concentrator and pings work fine there.
* Trace route shows the ping getting to our 3005 but stops there (good tracert shows a router and host at the other end)
* Concentrator setting on 3005 have not changed
* Firmware for our 3005 was upgraded 5 days ago. (just before problem was noticed)
* Other B2B links to other clients do not having issues. (All others Cisco to Cisco)
Is there a way to trace packets through the 3005 concentrator? I'd like to verify the packet enters the tunnel and find out where it stops.
An obvious step is to roll back the firmware and see if the problem is resolved.
