Community Member
Intermittent VPN Client issue
Hi. We're behind a cisco 1841 ADSL router. Im trying to VPN out to a customer site using the cisco vpn client.
I can do this from our 'spare' adsl line with no router on it no problem, so all my software and configs are correct on my laptop.
However, something on my router is stopping me from getting out.
Here are my access-lists and interfaces. Any ideas?
interface Dialer0
ip address our1841adsl 255.255.255.248
ip access-group 102 in
Extended IP access list 102
10 permit udp any eq domain any (381 matches)
20 permit tcp any any established (14902 matches)
30 permit tcp any host ourwebserver eq www (1 match)
40 permit tcp any host ourwebserver eq 443
50 permit tcp any host ourmailserver eq 1723
60 permit tcp any host ourmailserver eq smtp (10 matches)
70 permit tcp any host ourmailserver eq www (1 match)
80 permit tcp any host ourmailserver eq 443
90 permit gre any host ourmailserver (7823 matches)
100 permit tcp any host our1841adsl eq 1723
110 permit gre any host our1841adsl (5399 matches)
120 permit udp any any eq isakmp
130 permit udp any any eq non500-isakmp (331 matches)
140 permit esp any any
150 permit tcp any host summitelse eq ftp-data
160 permit tcp any host summitelse eq ftp
170 permit tcp any host summitelse eq www
180 permit tcp any host summitelse eq 443
190 permit tcp any host summitelse eq www
Extended IP access list 150
10 permit ip host 10.1.2.4 any
20 permit tcp host 10.1.2.5 any eq 3101
30 permit tcp 10.1.2.0 0.0.0.255 any eq 1723 (3 matches)
40 permit gre 10.1.2.0 0.0.0.255 any
50 permit tcp 10.1.2.0 0.0.0.255 any eq 3389
60 permit ip 10.1.2.0 0.0.0.255 host 81.179.43.100
70 permit tcp 10.1.2.0 0.0.0.255 any eq telnet
80 permit udp 10.1.2.0 0.0.0.255 any eq isakmp (3 matches)
90 permit udp 10.1.2.0 0.0.0.255 any eq non500-isakmp
100 permit udp 10.1.2.0 0.0.0.255 any eq 10000
110 permit esp 10.1.2.0 0.0.0.255 any
120 permit tcp host 10.1.2.8 any eq smtp
130 permit tcp 10.1.2.0 0.0.0.255 any eq 8200 (1 match)
150 permit udp 10.1.2.0 0.0.0.255 any eq 62515
160 permit tcp 10.1.2.0 0.0.0.255 any eq 10000 (1 match)
ip nat inside source list 150 interface Dialer0 overload
ip nat inside source static tcp 10.1.2.105 20 summitelse 20 extendable
ip nat inside source static tcp 10.1.2.105 21 summitelse 21 extendable
ip nat inside source static tcp 10.1.2.105 80 summitelse 80 extendable
ip nat inside source static tcp 10.1.2.106 80 summitelse 80 extendable
ip nat inside source static tcp 10.1.2.106 443 summitelse 443 extendable
ip nat inside source static tcp 10.1.2.8 80 anotherserver 80 extendable
ip nat inside source static tcp 10.1.2.8 443 anotherserver 443 extendable
ip nat inside source static tcp 10.1.2.4 25 sbs server 25 extendable
ip nat inside source static tcp 10.1.2.4 80 sbs server 80 extendable
ip nat inside source static tcp 10.1.2.4 443 sbs server 443 extendable
ip nat inside source static tcp 10.1.2.4 1723 sbs server 1723 extendable
ip nat inside source static 10.1.2.4 sbs server extendable
ip nat inside source static tcp 10.1.2.1 1723 our1841adsl 1723 extendable
134
