Community Member
Intra interface
Bet no one can solve this one
I have a cisco ASA and 2 877
The outside interface is connected to the internet, nothing on the inside
The 2 877 are also connected to the internet.
I have 2 VPN's that connect to the outside of the ASA.
Both tunnels are up.
But am unable to ping from one 877 to the other 877 via the VPN's.
I have intra interface enabled and sysopt connection permit-vpn
Tho I did set the vpn's up with match address statments.
I have been on this for ove a week and im starting to lose the plot.
Any help very much appricated.
Richard
1 ACCEPTED SOLUTION
Re: Intra interface
access-list 100 extended permit ip 10.20.30.0 255.255.255.0 10.20.40.0 255.255.255.0
no access-list 100 extended permit ip any any
access-list 101 extended permit ip 10.20.40.0 255.255.255.0 10.20.30.0 255.255.255.0
no access-list 101 extended permit ip any any
and modify ACL on the spokes accordingly
after that
initiate traffic from one spoke to another
and show
sh crypto isakmp sa
sh crypto ipsec sa
on all devices
Re: Intra interface
show ASA's configuration
Community Member
Re: Intra interface
ciscoasa# sh run
: Saved
ASA Version 8.0(3)
hostname ciscoasa
enable password xxx
names
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address *.*.*.* 255.255.255.252
interface GigabitEthernet0/1
nameif HQ
security-level 0
no ip address
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address 192.168.1.200 255.255.240.0
passwd xxx
ftp mode passive
same-security-traffic permit intra-interface
pager lines 24
mtu outside 1500
mtu HQ 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
route outside 0.0.0.0 0.0.0.0 195.*.*.*
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set intra esp-3des esp-sha-hmac
crypto map Labs 10 match address 100
crypto map Labs 10 set peer *.*.*.*
crypto map Labs 10 set transform-set intra
crypto map Labs 10 set security-association lifetime seconds 86400
crypto map Labs 11 match address 101
crypto map Labs 11 set peer *.*.*.*
crypto map Labs 11 set transform-set intra
crypto map Labs 11 set security-association lifetime seconds 86400
crypto map Labs interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet 192.168.0.0 255.255.240.0 management
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
tunnel-group *.*.*.* type ipsec-l2l
tunnel-group *.*.*.* ipsec-attributes
pre-shared-key *
tunnel-group 88.*.*.* type ipsec-l2l
tunnel-group 88.*.*.* ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
ciscoasa#
Re: Intra interface
after that
and show
sh crypto isakmp sa
sh crypto ipsec sa
on all devices
Community Member
Re: Intra interface
Thanks m8
Not really a CCIE question was it.
Been messing around with everything but so obvious.
169
