IOS WebVPN Citrix problem (error opening ICA file)
Hi All,
I have setup a 1841 Router with WebVPN, behind a 837 internet router. I have natted through port 443.
I have a Citrix server in side and am publishing it through the WebVpn.
I can connect to the Web Interface but can not launch applications. If I use the activeX component nothing happens at all. If I use the Java client I get an error "Error opening ICa file" "The address of an application server must be specified"
I have internally created certificates installed on the router and the root certificate installed as trusted in IE and Java.
There is an error logging on the 1841 each time I try to launch an application.
Jun 22 05:02:08.246: %TCP-2-INVALIDTCB: Invalid TCB pointer: 0x63A24534 -Process= "SSLVPN_PROCESS", ipl=
0, pid= 120 -Traceback= 0x60AD545C 0x61180F74 0x6117E9B8 0x61BBD2C4 0x61BBAB20 0x61BBB104 0x61BBEDD8 0x61
BCDA0C
Here is the running config without the real names or IPs.
Thanks for any suggestons. I have spent ages on this so far.
bob#s run
Building configuration...
Current configuration : 8679 bytes
! Last configuration change at 15:03:08 NZST Thu Jun 22 2006
version 12.4
hostname bob
boot-start-marker
boot-end-marker
no logging buffered
aaa new-model
aaa authentication login default local
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa session-id common
resource policy
clock timezone NZST 12
clock summer-time NZDT recurring 1 Sun Oct 2:00 last Sun Mar 2:00
ip cef
ip domain name mytestwebvpn4.co.nz
ip name-server 10.73.220.4
crypto pki trustpoint TP-self-signed-117527664
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-117527664
revocation-check none
rsakeypair TP-self-signed-117527664
crypto pki trustpoint mytestwebvpn4.org.nz
enrollment terminal
serial-number
fqdn bob.mytestwebvpn4.co.nz
ip-address FastEthernet0/0
password
subject-name OU=MY_OU, CN=bob.mytestwebvpn4.co.nz, C=NZ
revocation-check crl
rsakeypair SDM-RSAKey-1150934803000
crypto pki certificate chain TP-self-signed-117527664
certificate self-signed 01
D8AC05A8 6B2F9945 3E
quit
crypto pki certificate chain mytestwebvpn4.org.nz
certificate 61C2A6A000000000000F
8C4E7AB
quit
certificate ca 2F2FAD22B439B28F4BDB0CF2978A5E85
DDEBC0 99175B8C FCD38DF6 E586759C
6C5FA52A B3F7DF
quit
interface FastEthernet0/0
ip address 192.168.193.222 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.73.220.248 255.255.255.0
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 192.168.193.1
ip http server
ip http secure-server
access-list 101 remark Outside access list inbound traffic
access-list 101 permit tcp any host 192.168.193.222 eq 443
access-list 101 deny ip any any log
scheduler allocate 20000 1000
webvpn gateway sample_1
ip address 192.168.193.222 port 443
ssl trustpoint mytestwebvpn4.org.nz
inservice
webvpn context Default_context
ssl authenticate verify all
no inservice
webvpn context test_1
title "Test Web VPN"
title-color #669999
secondary-color white
text-color black
url-list "Printer"
heading "HTTP Printer"
url-text "HP Printer" url-value "http://10.73.220.38"
url-list "SDMCitrixServerList2"
heading "My Citrix farm"
url-text "server2" url-value "http://10.73.220.71/Citrix/MetaFrame/auth/login.aspx"
login-message "You must be authorised to access this network."
policy group NUTS01_RDP
url-list "Printer"
hide-url-bar
citrix enabled
default-group-policy NUTS01_RDP
aaa authentication list default
gateway sample_1
inservice
end
bob#
1 REPLY
Silver
Re: IOS WebVPN Citrix problem (error opening ICA file)
Java client is not configured properly,because of that the error appears
866
