Community Member
ip dhcp snooping issue
   Hi all,
I am having trouble getting the dhcp snooping to work on a stacked 3750 when a rogue DHCP server is plugged in to the network. I have configured dhcp snooping on one of our user switches with the following commands.
ip dhcp snooping
ip dhcp snooping vlan 11
no ip dhcp snooping information option
int range fa1/0/1 - 48
ip dhcp snooping limit rate 100
VLAN Name                             Status    Ports
11   JKT_Net_DHCP_1
interface FastEthernet1/0/43
description  DHCP Subnet 1
switchport access vlan 11
switchport mode access
switchport port-security maximum 3
switchport port-security aging time 1440
switchport port-security violation restrict
switchport port-security aging type inactivity
no logging event link-status
no snmp trap link-status
spanning-tree portfast
spanning-tree bpduguard enable
The configuration works in ther fact that users are still getting their IP address info from the DHCP server and i can see all the dhcp snooping bindings on the switch. But I'm having issues where when a rogue dhcp device is plugged in to one of the user ports i.e fa1/0/43 on the user subnet, and do an ipconfig /release /renew on a machine on the same VLAN, i am still getting a DHCPOFFER from the rogue device and the machine ends up with the wrong IP address.
Currrently the real DHCP server sits off a network behind the firewall, with a layer 3 link (running OSPF) between the user switch to the distribution switch. I have enabled the dhcp snooping on the link from the distribution switch to the real DHCP server (shown below).
DHCP snooping trusted interface
interface GigabitEthernet1/0/9
description JKTADC01 - LAC 1
switchport access vlan 21
ip dhcp snooping trust
I have also attached a network diagram of the network setup.
I would like to stop the rogue server from being able to give out ip addresses.
Can someone shed some light on this topic please?
Kind regards,
Everyone's tags (2)
