IP INSPECT not working with POP3
I'm running a Cisco 2600 with version 12.2.23 software that is configured for CBAC. Everything works fine except for POP3. I get a 550 error (unable to relay) message when try to reply to an email. When I remove the IP Inspect commmand from the interface, it works fine. I even allowed everything on the Access-list with ip inspect turned on and it does not work. Any suggestions?
Re: IP INSPECT not working with POP3
Any update on this? what was the problme?
This sounds more like an inspect SMTP error than anything relating to POP3. CBAC currently has nothing that inspects POP3 traffic specifically (except the TCP inspection). If you just remove the inspect smtp command from the global config but leave the rest of the inspect statements in place, does it work? If it does, you can re-enable the SMTP inspection and enable syslogging to see exactly why CBAC is dropping the packets. We are adding ESMTP support in later 12.3T code but for now, the SMTP inspection only allows these SMTP commands in the control channel:
DATA
EHLO
EXPN
HELO
HELP
MAIL
NOOP
QUIT
RCPT
RSET
SAML
SEND
SOML
VRFY
If it sees anything else, it drops the packet.
Hope this gives you some ideas.
Scott
117
