IP pool for VPN clients ?
Zouyu
Hi all
Is it possible to assign IP address within LAN in to a remote vpn client ?
with the example in this exact scenario :
http://www.cisco.com/warp/public/707/25a.gif
can I set an IP local pool in router as 10.2.2.10 - 10.2.2.20
the problem is any remote client can establish vpn connection with assigened IP (such as 10.2.2.10/32), but it cannot access any resources in LAN.
Thanks for your help.
9 Replies 9
spremkumar
Level 9
Level 9
hi
In your setup over here which device acts as the VPN termination point . is it a pix or a router ??
if possible can you post out the relevant config here ??
regds
We've setup a Cisco 3640 as the VPN gateway for remote users.
config is here:
r3640-VPN>en
Password:
r3640-VPN#show run
Building configuration...
Current configuration : 5146 bytes
! Last configuration change at 17:25:33 GMT Tue Feb 14 2006
! NVRAM config last updated at 17:25:34 GMT Tue Feb 14 2006
version 12.4
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service udp-small-servers
service tcp-small-servers
hostname r3640-VPN
boot-start-marker
boot-end-marker
logging buffered 409600 debugging
enable secret 5 $1$yVaS$iEAlCgSYVALCBlFE7OyzB0
aaa new-model
aaa authentication login userauthen local
aaa authentication ppp default local
aaa authorization network groupauthor local
aaa session-id common
resource policy
clock timezone GMT 8
ip cef
ip name-server 10.71.0.61
ip ssh rsa keypair-name ssh-key
ip ssh version 2
username cisco password 0 cisco
crypto isakmp policy 3
hash md5
authentication pre-share
group 2
crypto isakmp client configuration group vpnuser
key shlear
dns 10.71.0.61
wins 10.67.0.61
domain vpn.foo.org
pool ippool
include-local-lan
netmask 255.255.255.255
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10
set transform-set myset
crypto map mymap client authentication list userauthen
crypto map mymap isakmp authorization list groupauthor
crypto map mymap client configuration address initiate
crypto map mymap client configuration address respond
crypto map mymap 10 ipsec-isakmp dynamic dynmap
interface FastEthernet0/0
description " Inside Interface "
ip address 10.71.0.99 255.255.254.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description " Wan Interface "
no ip address
no ip proxy-arp
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dialer1
description " PPP-Dialup "
bandwidth 512
ip address negotiated
no ip redirects
ip local-proxy-arp
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer redial interval 5 attempts 0 re-enable 5
dialer-group 1
no cdp enable
ppp authentication pap chap callin
ppp chap hostname name
ppp chap password pass
ppp pap sent-username name password pass
ppp ipcp dns request
crypto map mymap
ip local pool ippool 10.71.0.241 10.71.0.254
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 Dialer1
ip nat inside source route-map no-nat interface Dialer1 overload
access-list 1 permit 10.71.0.0 0.0.1.255 log
access-list 101 deny ip 10.71.0.0 0.0.1.255 10.71.0.240 0.0.0.15
access-list 101 permit ip 10.71.0.0 0.0.1.255 any
dialer-list 1 protocol ip permit
snmp-server community Private RW
route-map no-nat permit 10
match ip address 101
control-plane
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
password cisco
transport input telnet ssh
ntp clock-period 17180020
ntp server 130.149.17.21
end
r3640-VPN#
hi
Can you remove include-local-lan from you isakmp config and check for the access ?
Is there any specific reason behind using the same in your config here ??
regds
It did not work after I removed "include-local-lan" and "netmask 255.255.255.255" commands.
I've been asked to follow restricted instructions to config IP pool for VPN clients with same addressing scheme as LAN's, even when it worked when I'd tried to set a IP subnet for vpn clients other than LAN's.
i have a similar setup and have one public ip....same problem here....vpn client can get the ip address (i have tried same and different ip range with LAN) from the vpnpool but can't access any resources in the LAN.
My router is Cisco 1841 with ADSL connection and the lastest VPN client 4.800.xxx.
I have a similar setup (with router but have a check point firewall behind the router) last time but it works 'coz i was using a public ip range for my vpn pool.....
anyone can help??? Thanks in advance...
I think we may have found out where the problem was.
It was all about NAT, all that we need to do was to set different ACLs to make sure any VPN flows could bypass NAT.
down below is our running-config:
version 12.4
service password-encryption
enable secret
aaa new-model
resource policy
ip cef
ip ssh version 2
hash md5
group 2
key
dns 1.1.0.61
wins 1.7.0.61
domain foo.org
pool ippool
acl 190
include-local-lan
reverse-route
ip address 192.168.0.127 255.255.255.0
ip nat inside
duplex auto
speed auto
no ip address
no ip proxy-arp
duplex auto
speed auto
pppoe enable
no cdp enable
interface Dialer1
bandwidth 512
no ip redirects
ip local-proxy-arp
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp chap password
crypto map mymap
ip local pool ippool 192.168.0.249 192.168.0.254
ip route 192.168.0.0 255.255.0.0 192.168.0.1
ip route 192.168.1.101 255.255.255.255 192.168.0.1
ip route 192.168.2.37 255.255.255.255 192.168.0.1
access-list 1 permit 192.168.0.0 0.0.0.255 log
access-list 101 deny ip 192.168.0.0 0.0.0.255 192.168.0.248 0.0.0.7
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
access-list 180 permit ip 192.168.0.0 0.0.0.255 192.168.0.248 0.0.0.7
access-list 190 permit ip 192.168.0.0 0.0.255.255 192.168.0.248 0.0.0.7
line con 0
line aux 0
line vty 0 4
password cisco
ntp clock-period 17180011
ntp server 202.112.0.38
end
reverse-route
what is reverse-route for??.... i haven't tried yet...but i was using different ip range and denied the NAT (same as the above example)....still having the same problem...i.e the pool is 192.168.81.1-254 and the LAN is 192.168.82.0...how is the routing like since the pool and the LAN is in different subnet??
According to the Cisco IPSec config manual, Reverse Route Injection is the ability for static routes to be automatically inserted into the routing process for those networks and hosts protected by a remote tunnel endpoint. These protected hosts and networks are known as remote proxy identities.
http://www.cisco.com/en/US/partner/products/ps6350/products_configuration_guide_chapter09186a0080455af1.html
Would you lease post your network diagram and config ?
Thanks for your reply...i have go through the RRI documentation...
My config. is similar to yours....so the necessary for the VPN client to work are:
1. Must do 'nonat' for pool addresses
2. Must do RRI (either using same IP address range with the LAN or different ip range)
My other problem is the VPN client....i have actually Huawei's VPN client and Cisco VPN client installed at the same pc....the Cisco VPN client can grabbed the ip for pool but can't access the LAN resources...after removed the Huawei's VPN client, everything is ok....
