ip tcp adjust-mss: unrecognized command
mario.laniel
I need to use that commands to lower maximum segment size but I tried multiple 12.2(#) versions but I can not seems to find one that support that command. Does anyone have a clue?
Thanks everyone.
Mario
nsteup
Hi Mario,
take a look a following Posting:
5.Configure an IP address and subnet mask on the Cisco 827 Ethernet interface.
(Optional) Enable NAT inside on the Ethernet interface.
Router#configure terminal
Router(config)#interface ethernet 0
Router(config-if)#ip tcp adjust-mss 1452
!--- If the ip tcp adjust-mss 1452 command is not supported, try
!--- ip adjust-mss 1452. If this command is not supported,
!--- upgrade to the latest Cisco 827 software or follow the
!--- procedure in the Possible Required Configuration Steps on the PC.
Router(config-if)#ip address
Router(config-if)#ip nat inside
Router(config-if)#no shut
Router(config-if)#end
I did the command on several IOS-Versions 12.2.1 to 12.2.10 on Routers 806 with IPsec-FW-Software. Never had a problem to adjust the segment-size for DSL-Connections. If your Software is able to provide PPPoE, then you MUST be able to adjust your mss.
Hope this helps
Kind Regards
Norbert
Thanks for the quick response, I downloaded 12.2(4T) and the command is now supported.
Mario
