Unicast Reverse Path Forwarding
Unicast Reverse Path Forwarding (Unicast RPF) can be optionally configured. Unicast RPF is used to verify that the source address is in the Forwarding Information Base (FIB). The ip verify unicast vrf command is configured in interface configuration mode and is enabled for each VRF. This command has permit and deny keywords that are used to determine if the traffic is forwarded or dropped.
SUMMARY STEPS
1. enable
2. configure terminal
3. interface type number [name-tag]
4. ip policy route-map map-tag
5. ip verify unicast vrf vrf-name deny | permit
6. end
How different is this command from :
ip verify unicast source reachable-via any allow-self-ping ( Can this command be used on VRF interfaces)
