IPSEC doenst work after a reboot
I have a pix525 running 6.2.2.
We have an IPSEC tunnel with Checkpoint FW 4.1. This was working fine
Due to some reason we have to reboot the PIX. now the the tunnel is broken.
This is the error i get at the checkpoint side .
Errors seen:
Error IKE: Quick Mode Received Notification from Peer: no proposal chosen.
and encryption fail reason: Packet is dropped as there is no valid SA.
and i tried clearing the sa using
clear crypto ipsec sa
clear crypto isa sa
On the PIX.
but no use what could be the problem??
1 REPLY
Re: IPSEC doenst work after a reboot
Hi Batchu,
When you reboot one side in an Interoperability scenario, you should clear the IKE & IPSec SA's on both the sides, including on the Checkpoint side.
Once thats done and this still occurs, then make sure you only have one proposal chosen for this tunnel on both the sides.
The best chance you have to get things working with checkpoint
- use v4.1 sp 1
- use ONLY one transform
- use only one ISAKMP policy
- make sure rekey values are 100% equal
When testing, don't declare success until you have tested re-keying. Also make sure you are successful bringing the tunnel up from both sides.
Hope this helps,
Aamir Waheed,
Cisco Systems, Inc.
CCIE#8933
227
