Community Member
IPsec LAN to LAN Tunnel on VPN 3030 Concentrator with router Config for DH
hi.
this is tom.
my site is two VPN device.
one device is VPN Concentrator 3030.
other deivce is 1712 IOS Router
and 1712 Router assigned Public dhcp IP Address(ADSL). VPN Concentrator with SSL VPN Config and SSL VPN User authentication is SDI Server
Concentrator's Base Group is Default SSL VPN Group
Router with Remote Access config connect VPN Concentrator
Connection fail.and debug router error message..
Re: IPsec LAN to LAN Tunnel on VPN 3030 Concentrator with router
Do you have a copy of the ISAKMP and IPSEC logs from the VPN3000 at the same time the logs were captured from the router. From the debugs, it looks like the router is getting stuck at Key Exchange. Could be an issue with pre-shared keys not matching or the VPN3000 receiving the packet and dropping it or maybe a firewall inbetween that is blocking traffic.
Arul
** Please rate all helpful posts **
Community Member
VPN 3000 Concentrator log Message..
1 01/28/2008 08:48:08.150 SEV=5 IKE/172 RPT=17 211.193.56.197
Group [VPNC_Base_Group]
Automatic NAT Detection Status:
Remote end is NOT behind a NAT device
This end is NOT behind a NAT device
5 01/28/2008 08:48:08.250 SEV=4 IKE/127 RPT=25 211.193.56.197
Xauth required but selected Proposal does not support xauth,
Check priorities of ike xauth proposals in ike proposal list
8 01/28/2008 08:48:08.250 SEV=5 IKE/194 RPT=26 211.193.56.197
Sending IKE Delete With Reason message: No Reason Provided.
10 01/28/2008 08:52:13.570 SEV=4 CONFIG/17 RPT=21
Done writing configuration file, Success.
11 01/28/2008 08:52:18.690 SEV=5 IKE/172 RPT=18 211.193.56.197
15 01/28/2008 08:52:18.800 SEV=4 IKE/127 RPT=26 211.193.56.197
Community Member
Cisco Router Config - add attachments
Cisco VPN Concentrator log message
2 01/30/2008 06:14:52.250 SEV=4 IKE/48 RPT=162 116.88.39.5
Error processing payload: Payload ID: 1
3 01/30/2008 06:15:02.240 SEV=4 IKE/48 RPT=163 116.88.39.5
4 01/30/2008 06:15:12.240 SEV=4 IKE/48 RPT=164 116.88.39.5
5 01/30/2008 06:15:22.240 SEV=4 IKE/48 RPT=165 116.88.39.5
6 01/30/2008 06:15:32.260 SEV=4 IKE/48 RPT=166 116.88.39.5
7 01/30/2008 06:15:42.250 SEV=4 IKE/48 RPT=167 116.88.39.5
1025
