IPSec & PIX with clients
I am having trouble with a client behind a PIX. I want the client to be able to access any outside address (the internet) The trickey part is the PIX is just setup right now for IPsec. I have PC's on the outside using VPN3000 client software that need to access this client behind the PIX. The MAIN priblem is I want the client behind the PIX to be able to also access any PC on the outside with out using IPsec(the NET). For some reason I can't get the client to be able to access any hosts on the Outside itnerface. The IPsec works fine however, I believe this is a access list issue I have tried everyting.. Anybody now how to do this..?
thanks!
VIP Purple
Re: IPSec & PIX with clients
Could you post config?
The IPs are not excatly the same; I am looking for syntax mostly.. thanks for the help!
Here is the dump of the PIX:
PIX Version 6.1(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname pixfirewall
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list 101 permit ip 192.168.30.0 255.255.255.0 10.10.5.0 255.255.255.0
access-list 101 permit icmp any any
pager lines 24
logging on
logging console debugging
logging monitor debugging
logging buffered debugging
logging trap debugging
logging history debugging
interface ethernet0 10baset
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside 192.168.10.1 255.255.255.248
ip address inside 192.168.30.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool xyzpool 10.10.5.1-10.10.5.254
pdm history enable
arp timeout 14400
global (outside) 1 192.168.10.40
nat (inside) 0 access-list 101
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) 192.168.10.1 192.168.30.1 netmask 255.255.255.255 0 0
static (inside,outside) 192.168.10.20 192.168.30.10 netmask 255.255.255.255 0 0
access-group 101 in interface outside
route outside 0.0.0.0 0.0.0.0 192.168.10.5 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
no floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set xyzset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set xyzset
crypto map xyzmap 10 ipsec-isakmp dynamic dynmap
crypto map xyzmap interface outside
isakmp enable outside
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup xyz address-pool xyzpool
vpngroup xyz split-tunnel 101
vpngroup xyz idle-time 1800
vpngroup xyz password ********
telnet timeout 5
ssh timeout 5
terminal width 80
---End
89
