IPSEC Problem
i am running OSPF using GRE tunnels (both OSPF packets and IPX packets are encrypted). The remote sites are using 3640 and the central sites are using 7200. All routers have hardware VPN modules.
The WAN is using BroadBand Ethernet.
The following messages are generated at some remote sites 3640 routers and the customers are very worried.
Jul 9 14:57:28 HKT: %HW_VPN-1-HPRXERR: Hardware VPN2/8: Packet Encryption/Decryption error, status=4609
Jul 9 14:58:08 HKT: %HW_VPN-1-HPRXERR: Hardware VPN2/8: Packet Encryption/Decryption error, status=4609
Jul 9 14:58:47 HKT: %HW_VPN-1-HPRXERR: Hardware VPN2/8: Packet Encryption/Decryption error, status=4609
Jul 9 14:59:28 HKT: %HW_VPN-1-HPRXERR: Hardware VPN2/8: Packet Encryption/Decryption error, status=4609
Can anyone know the cause of the above message..?
Also, at one remote site, the OSPF relationship is sometimes down and i have to reload the router. Once the router is reloaded, the OSPF relationship is re-built again..
i attach a config file for one remote site to your reference:
Current configuration : 4724 bytes
! No configuration change since last restart
version 12.2
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
hostname EDDRTKR1
logging buffered 4096 debugging
clock timezone HKT 8
ip subnet-zero
no ip source-route
no ip domain-lookup
ip ssh time-out 120
ip ssh authentication-retries 3
ipx routing 0060.7015.abc0
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
crypto isakmp key 852h address 10.15.247.8
crypto isakmp key 852h address 10.15.247.208
crypto ipsec transform-set edset esp-3des esp-md5-hmac
mode transport
crypto map edmap local-address Loopback0
crypto map edmap 10 ipsec-isakmp
set peer 10.15.247.8
set transform-set edset
match address 110
crypto map edmap 20 ipsec-isakmp
set peer 10.15.247.208
match address 120
call rsvp-sync
interface Loopback0
description IP address for router ID of OSPF
ip address 10.15.247.54 255.255.255.255
interface Tunnel0
description Wu Chung EDDRMWCH1
ip address 10.15.237.42 255.255.255.252
ip mtu 1500
ipx network FED0028
ipx output-sap-filter 1000
ipx update interval sap 120
traffic-shape rate 1000000 25000 25000 1000
tunnel source Loopback0
tunnel destination 10.15.247.8
crypto map edmap
interface Tunnel1
description Sai Kung EDDRMSK1
ip address 10.15.238.42 255.255.255.252
ip mtu 1500
ipx network FEE0028
tunnel destination 10.15.247.208
crypto map edmap
interface Ethernet0/0
description segment at Tin Kwong Road Training Unit
ip address 10.15.232.225 255.255.255.248
ip mask-reply
no ip proxy-arp
half-duplex
ipx network F365000 encapsulation SAP
interface Ethernet0/1
description BroadBand (VP685382)
ip address 128.15.237.10 255.255.255.128
no ip unreachables
no ip proxy-arp
half-duplex
ipx network FF8D000
no cdp enable
crypto map edmap
interface FastEthernet1/0
description Connected to EDDRTKR2 FastEthernet 2/0
ip address 10.15.232.13 255.255.255.252
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
interface FastEthernet1/1
no ip address
shutdown
duplex auto
speed auto
router ospf 333
log-adjacency-changes
network 10.15.0.0 0.0.255.255 area 128.15.0.0
ip classless
ip route 10.15.247.8 255.255.255.255 128.15.237.1
ip route 10.15.247.208 255.255.255.255 128.15.237.2
no ip http server
ip pim bidir-enable
logging trap debugging
logging 10.99.3.24
logging 10.99.3.25
logging 10.99.3.21
logging 10.15.4.5
access-list 110 permit gre host 10.15.247.54 host 10.15.247.8
access-list 120 permit gre host 10.15.247.54 host 10.15.247.208
access-list 1000 permit FFFFFFFF 4
access-list 1000 permit FFFFFFFF 107
access-list 1000 permit FFFFFFFF 526
access-list 1000 permit FFFFFFFF 531
access-list 1000 permit FFFFFFFF 37E
access-list 1000 permit FFFFFFFF 44C
access-list 1000 permit FFFFFFFF 30C
access-list 1000 permit FFFFFFFF 901
access-list 1000 permit FFFFFFFF 152
snmp-server community ednet123 RO
snmp-server host 10.99.3.11 ednet123
snmp-server host 10.99.3.12 ednet123
tacacs-server host 10.99.3.24
tacacs-server host 10.99.3.25
tacacs-server key ciscotac
dial-peer cor custom
line con 0
exec-timeout 15 0
password 7 1300131C0E18
speed 19200
flowcontrol hardware
line aux 0
exec-timeout 15 0
password 7 070A25424B1D
transport input all
line vty 0
exec-timeout 15 0
password 7 03015F05031B
line vty 1
exec-timeout 15 0
password 7 141216050910
line vty 2
exec-timeout 15 0
password 7 09494A071C11
line vty 3
exec-timeout 15 0
password 7 045E0F080A35
line vty 4
exec-timeout 15 0
password 7 15170F02013E
ntp clock-period 17179977
ntp source Loopback0
ntp server 10.15.247.9
ntp server 10.15.247.8
end
1 REPLY
Re: IPSEC Problem
This message is related to bug CSCdu40546, and is a decfect in teh way the hardware encryption card handles large encrypted packets. You'll probably see this error every time the router tries to pass a large packet. Setting the MTU on the interfaces to 1500 usually works around it. The bug is also resolved in 12.2(3)T and higher.
122
