IPSec Tunnel between VPN 3000 & Check point firewall
Hi ,
I have established tunnel between VPN Concentrator & check point.
After few hours its gets disconnected & then it takes lot of time to get connect ted.
I am getting continiously the following message...
IKE Initiator: New Phase 1, Intf 2, IKE Peer 214.x.x.x
local Proxy Address 192.x.x.x , remote Proxy Address 214.x.x.x,
SA (L2L: Checkpoint)
I am using DES-56
Is there anything that i need to check ?
Thanks ....Rajneel
Re: IPSec Tunnel between VPN 3000 & Check point firewall
Rajneel,
Make sure that your ipsec/isakmp lifetimes match on the concentrator with the checkpoint. The checkpoints default lifetimes is 7 days which the concentrator can't go that high, max is 1 day. Change the checkpoint to match whats configured on the concentrator. Hope this helps.
Kurtis Durrett
Thanks ..Kurtis ...
I will check that. What should be that Encryption / IKE Proposals settings on both the devices ?
Des or 3des, depending on your security policies. The sa lifetimes would also be determined by your security policies, some people like them to be short. But the max on the concentrator is 24 hours or 86400 seconds which is fine with most configurations.
Kurtis Durrett
Hi Kurtis ,
I am getting the following error on checkpoint
"IKE: Main Mode Sent Notification: no proposal chosen"
Regards ....Rajneel
Rajneel,
Which means something is not matching between the 2 devices. I've seen configurations with the concentrator that allows connections to it because it will try to match it up with one of its many active proposals allowing connections to it. But without checking this out, im much more familiar with the 3000 than the checkpoint, its hard for me to tell.
Have you followed this link:
http://www.cisco.com/warp/public/471/cp-3000.html
Kurtis Durrett
154
