ipsec tunnel intermittent packet loss
Well I hope this saves someone else some time.
If you're able to establish a L2L ipsec tunnel, but lose about 50% of your pings, turn off ip cef! that's probably on the first page of "vpns for beginners", but i didn't find any references to it here.
here's to wasted time...
matt
1 REPLY
Re: ipsec tunnel intermittent packet loss
Hey Matt,
Disabling ip cef works most of the time, however, if you have other services on that router, you cannot always go away from CEF.
Configuration guide for CEF support using IPSEC:
http://www.cisco.com/en/US/docs/ios/security/configuration/guide/sec_cfg_vpn_ipsec.html#wp1047537
As you can see there are a few tricks to overcome this problem, but if you don't use MPLS or some other CEF dependent applications (AutoQoS, Protocol discovery) you can just disable CEF globally.
Please rate if this helped.
Daniel
326
