IPsec with NAT between two routers
Hi, I've configured two Cisco 827 with a VPN but it doesn't work.
I don't any idea why. Can anybody help me?
Both have this IOS c820-k8osy6-mz.122-2.T4.bin
This is the configuration of the first router:
Almeria#sh run
Building configuration...
Current configuration : 2860 bytes
version 12.2
no parser cache
no service single-slot-reload-enable
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Almeria
logging rate-limit console 10 except errors
enable secret 5 $1iaeN5ZTQuELVXQEZv1
ip subnet-zero
ip ssh time-out 120
ip ssh authentication-retries 3
no ip dhcp-client network-discovery
crypto isakmp policy 20
hash md5
authentication pre-share
group 2
crypto isakmp key verde address 200.100.12.212
crypto ipsec transform-set miadsl esp-des esp-md5-hmac
crypto map mimapa 10 ipsec-isakmp
set peer 200.100.12.212
set transform-set miadsl
match address 101
interface Ethernet0
ip address 172.2.2.99 255.255.255.0
ip nat inside
interface ATM0
no ip address
no atm ilmi-keepalive
bundle-enable
dsl operating-mode auto
interface ATM0.1 point-to-point
ip address 200.100.12.217 255.255.255.240
ip nat outside
pvc 8/32
encapsulation aal5snap
crypto map mimapa
ip nat inside source list 1 interface ATM0.1 overload "I can´t erase this line"
ip nat inside source route-map nonat interface ATM0.1 overload
ip nat inside source static tcp 172.2.2.99 23 200.100.12.217 23 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 ATM0.1
ip route 192.168.100.0 255.255.255.0 200.100.12.212
no ip http server
access-list 101 permit ip 172.2.2.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 110 deny ip 172.2.2.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 110 permit ip 172.2.2.0 0.0.0.255 any
route-map nonat permit 10
match ip address 110
line con 0
stopbits 1
line vty 0 4
password 7 1316161E0A1
login
scheduler max-task-time 5000
end
This is the configuration of the second router:
Barcelona#sh run
Current configuration : 1759 bytes
version 12.2
no parser cache
no service pad
hostname Barcelona
enable secret 5 $1$MZtHAAIVm/vno0l0
ip subnet-zero
ip ssh time-out 120
hash md5
group 2
crypto isakmp key verde address 200.100.12.217
set peer 200.100.12.217
match address 101
interface Ethernet0
ip address 192.168.100.250 255.255.255.0
ip nat inside
no ip route-cache
no ip mroute-cache
interface ATM0
no ip address
no ip route-cache
no ip mroute-cache
bundle-enable
hold-queue 224 in
ip address 200.100.12.212 255.255.255.240
ip nat outside
no ip route-cache
no ip mroute-cache
pvc 8/32
crypto map mimapa
ip nat inside source static tcp 192.168.100.250 23 200.100.12.212 23 extendable
ip classless
ip route 172.2.2.0 255.255.255.0 200.100.12.217
ip http server
access-list 101 permit ip 192.168.100.0 0.0.0.255 172.2.2.0 0.0.0.255
access-list 110 deny ip 192.168.100.0 0.0.0.255 172.2.2.0 0.0.0.255
access-list 110 permit ip 192.168.100.0 0.0.0.255 any
line con 0
stopbits 1
line vty 0 4
password 7 0612D4D5
login
end
I ping to 172.2.2.150 ( a device of the LAN of Almeria) from Barcelona and I recive this U...U
If I put debug crypto ipsec and debug crypto isakmp i don't get nothing
I boss have told me that must work tomorrow, so I need your help please!!!!
Thanks in advance.
1 REPLY
Re: IPsec with NAT between two routers
You didn't define the list 1 on Almeria.
Try to define it and see what happens.
Another thing you can do is the following:
remove the route map nonat;
Try to use the following nat command instead:
ip nat inside source list 110 interface ATM0.1 overload
111
