12-27-2003 08:24 AM - edited 03-12-2019 05:31 PM
is it possible to connect with SSH (1.0 or 2.0) from one CISCO-Router/Switch to another CISCO-Router/Switch ?
i think a SSH connection to a Router/Switch is only possible from an Endstation (Windows/Linux/Unix),
isn't it ?
Solved! Go to Solution.
12-30-2003 05:15 AM
I don't know if Cisco supports SSH 2.0, but there are IOS-s that support ssh 1.0 and you can connect with ssh 1.0 from a cisco device (if it supports) to any device with
Router# ssh ?
-c Select encryption algorithm
-l Log in using this user name
-o Specify options
-p Connect to this port
WORD IP address or hostname of a remote system
Router# ssh x.x.x.x
12-27-2003 09:38 AM
I am not aware of any IOS image that has a ssh client built into it
12-30-2003 05:15 AM
Router# ssh ?
-o Specify options
Router# ssh x.x.x.x
12-30-2003 06:00 AM
it works fine with SSH v1.5
IOS is c6msfc-pk2sv-mz.121-13.E3.bin
router#sh ip ssh
SSH Enabled - version 1.5
Authentication timeout: 120 secs; Authentication retries: 3
router#
T-H-A-N-K Y-O-U
