Is it possible to set the speed and duplex on the sniff interface.
Not sure on how to set the above on the i386 Solaris platform with the spwr interface.
1 REPLY
Re: Is it possible to set the speed and duplex on the sniff inte
Not that I am aware of for the spwr interface.
If you need to set speed and duplex, I would recommend switching your iprb and spwr interfaces. Using spwr for command and control and iprb for sniffing. You can set these parameters with the iprb driver. You can do a man iprb on most Solaris boxes to get the syntax. The iprb driver config file is located in /kernel/drv/iprb.conf.
-ForceSpeedDuplex
Default: 5 (Auto-negotiate)
Allowed Values: 4 (100 FDX)
3 (100 HDX)
2 (10 FDX)
1 (10 HDX)
Specify the speed and duplex mode for each instance.
Example: ForceSpeedDuplex=5,4;
Sets iprb0 to autonegotiate and iprb1 to 100 FDX.
124
