Is key exchange cause application fail?
Are there any issues with key exchanges causing applications to drop data connections while connected via VPN.
Ex. Some file transfers have been dropped. Also an application they are running (locally) called Team Coherence drops its connection when doing a bulk transfer.
Her is my current config:
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map client authentication samurai
crypto map outside_map interface outside
crypto map outisde_map 20 ipsec-isakmp
crypto map outisde_map 20 set pfs group2
isakmp enable outside
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash sha
isakmp policy 20 group 2
isakmp policy 20 lifetime 3600
vpngroup group address-pool addr_pool
vpngroup group dns-server <private IP>
vpngroup group wins-server <private IP>
vpngroup group default-domain siscocorp.com
vpngroup group split-tunnel siscocorp_splitTunnelAcl
vpngroup group idle-time 1800
vpngroup group password ********
According to my config the key exchange should only take place hourly.
Thanks in advance....
1 REPLY
Silver
Re: Is key exchange cause application fail?
The ISAKMP lifetime only applies to the keys used for IKE encryption that are generated using Diffie-Hellman. A separate set of keys are used for IPSec data encryption and the default is 8 hours. This can be changed with:
crypto ipsec security-association lifetime seconds xxx
However, tunnels are negotiated using the lowest lifetime of the two peers. If the other hosts asks for a lower time, then that one will be used.
So you're using a Cisco client VPN connection directly from the remote app server? The idle-timer is at 30 min. (1800 secs). Do hosts have quiet periods for 30 min? If so, the VPN connection will be dropped. This is probably the source of your issues.
83
