Is PDM installed?
Hello, I have enherited a pix installation and wanted to upgrade from 6.3 to 7.x. I do not know if PDM was ever installed? How can I tell if it was? Here is a sh ver if that helps.
Also, can you tell if I need to upgrade the flash memory from 16 to 64 for the upgrade?
TIA,
Gary
PIX1# sh ver
Cisco PIX Firewall Version 6.3(4)
Cisco PIX Device Manager Version 3.0(3)
Compiled on Fri 02-Jul-04 00:07 by morlee
PIX1 up 32 days 13 hours
Hardware: PIX-515E, 64 MB RAM, CPU Pentium II 433 MHz
Flash E28F128J3 @ 0x300, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
Encryption hardware device : VAC (IRE2141 with 2048KB, HW:1.0, CGXROM:1.9, FW:6.
5)
0: ethernet0: address is 000b.461f.2a41, irq 10
1: ethernet1: address is 000b.461f.2a42, irq 11
2: ethernet2: address is 0002.b3a4.543f, irq 5
Licensed Features:
Failover: Enabled
VPN-DES: Enabled
VPN-3DES-AES: Disabled
Maximum Physical Interfaces: 6
Maximum Interfaces: 10
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
This PIX has an Unrestricted (UR) license.
Serial Number: 806395271 (0x30109d87)
Running Activation Key: 0x68fbd2af 0xc2fa6629 0x34acc23f 0x6e15cdce
Configuration last modified by enable_15 at 08:26:46.270 UTC Thu Jul 27 2006
PIX1#
1 REPLY
Re: Is PDM installed?
Here are 2 ways to figure out if you have PDM installed on your Pix.
1. Type "sh flashfs"
PIX Ver 6.3 and higher (ver 3 filesystem)
file 0: PIX binary image
file 1: startup config
file 2: IPSec key and certificate information.
file 3: PDM image
file 4: Crashinfo (last saved traceback and show tech output)
file 5: filesystem record.
pdm-pix(config)# show flashfs
flash file system: version:3 magic:0x12345679
file 0: origin: 0 length:1941560 -PIX Binary Image
file 1: origin: 2621440 length:4909 -PIX Config
file 2: origin: 2752512 length:1917 -IPSec data
file 3: origin: 2883584 length:3126944 -PDM Binary Image
file 4: origin: 6029312 length:131072 -Crashinfo file
file 5: origin: 8257536 length:308 -Filesystem record
2. On an Internet Explorer browser running on a workstation connected to the PIX Firewall unit, enter the following:
https://pix_inside_interface_ip_address
where pix_inside_interface_ip_address is the IP address of the inside interface of your PIX Firewall
or simply look for pdm statements in the config.
Also, you only need 16 MB Flash. This link may also be useful
Guide for Cisco PIX 6.2 and 6.3 Users Upgrading to Cisco Security Appliance Software Version 7.0
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_70/pix_upgd/pixupgrd.htm
Hope that helps! If so, please rate.
107
