11-26-2005 10:35 PM - edited 03-09-2019 01:09 PM
hello,
is there any way an isa server on the outside of the pix can login to the domain which is inside of the pix?
note that we could only put a single default gateway on the isa which i have currently on the external interface and pointing to the router.
if i remove the default gateway on the external, and put a def gateway on the internal interface and point it to the outside interface of the pix, the i could login. But we can not do that coz we need the def gateway at the external interface.
thanks alot
11-27-2005 04:03 PM
Have you tried adding a static route on the ISA.
11-28-2005 10:12 PM
ya, actualy that has already solved the problem. we have added a route add command.
thanks a lot.
