ISAKMP and SAs
I just want to clarify something.
When Phase 1 & 2 IKE complete should I expect to see an ISAKMP SA on each end point?
For instance when I do "sh crypto isakmp sa" on each PIX should there be one regardless of which initiated the connection?
It looks this way but the life times are slightly different.
1 ACCEPTED SOLUTION
Silver
Re: ISAKMP and SAs
Yes you should. If you cant see the SA, clear the isakmp session and establish it again and see if it reappears
Gold
Re: ISAKMP and SAs
You are right
but command sh crypto isakmp sa is only about 1phase of IPSEC - in main mode you have 5 states with "sh crypto isakmp sa" command:
MM_NO_STATE,MM_SA_SETUP,MM_KEY_EXCH,MM_KEY_AUTH
and when is 1phase of Ipsec is esthablised QM_IDLE
more info you can find:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123cgcr/secur_r/sec_r1g.htm#wp1074075
2nd phase of IPSEC you can check with command "show crypto ipsec sa"
M.
Rate helpful post
Re: ISAKMP and SAs
Thanks for feedback.
Just to clarify, when I do:
sh crypto isakmp sa - should I see an SA on each peer with state QM_IDLE?
Obvisouly I see a "show crypto ipsec sa" on each.
I
Gold
Re: ISAKMP and SAs
Yes if you see somethig different than QM_IDLE it means 1 phase of IPSEC is not successfully esthablisde
Re: ISAKMP and SAs
OK, but i have an active tunnel but I don't see the QM_IDLE but if I do "sh ipsec sa" the tunnel is there and I can ping over it etc.
I'm guessing the tunnel came up from the other end, but should I see the QM_IDLE under the "sh isakmp sa".
Silver
Re: ISAKMP and SAs
Re: ISAKMP and SAs
I think I may have resolved it. One tunnel is to a PIX and one to Netscreen. I have SA of 24hrs.
I have noticed dead peer detection is enabled for the PIX connection (D) but not netsreen. For some reason the tunnel remains up but the sh ISAKMP sa disappers after a certain time.
I'm putting this down to the dead peer detection support on cisco.
182
