Community Member
Issue creating VPN
MY issue is that when the vpn is configured, and i try running a tracert to one of my remote pcs on the other side of the VPN, the VPN router is sending the the information to the internet and not attempting to open the tunnel. what am i doing wrong???
i'm using a cisco 1700 router and connecting to a cisco 3030 vpn concentrator
Current configuration : 1522 bytes
version 12.3
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
enable secret 5
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip audit po max-events 100
crypto isakmp policy 9
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key (Shared Key) address (IP ADDRESS of peer)
crypto ipsec security-association lifetime seconds 86400
crypto ipsec transform-set TS1 esp-3des esp-md5-hmac
crypto map crypmap 1 ipsec-isakmp
set peer (IP ADDRESS of peer)
set transform-set TS1
match address 101
interface Ethernet0
ip address (IP ADDRESS)
ip nat outside
half-duplex
crypto map crypmap
interface FastEthernet0
ip nat inside
speed auto
ip nat inside source list 1 interface Ethernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 (Default router)
no ip http server
no ip http secure-server
access-list 1 permit any
access-list 101 permit ip host (HOST on Local using NAT) host (Remote host 1)
access-list 101 permit ip host (HOST on Local using NAT) host (Remote host 2)
access-list 101 permit ip host (HOST on Local using NAT) host (Remote host 3)
access-list 101 permit ip host (HOST on Local using NAT) host (Remote host 4)
line con 0
line aux 0
line vty 0 4
password 7 PASSWORD
login
end
1 ACCEPTED SOLUTION
Re: Issue creating VPN
Hi Jim
You need to modify the access-list statement also the nat overload statement..
you need to deny the traffic between the 2 vpn networks getting natted..
you can verify the below link configuring up the same..
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a008009448f.shtml
regds
Hi Jim
regds
Community Member
I'v added the route map and configured to like the sample in the link provided(at lest to the best of my knowledge)and the router is still routing the information to the internet and not attempting to open the tunnel(pardon me if it is a obvious answer im quite a novice at routers)
Current configuration : 1563 bytes
version 12.3
hostname Router
boot-start-marker
boot-end-marker
enable secret ****
enable password ***
no mmi pvc
no aaa new-model
ip subnet-zero
ip cef
encr 3des
hash md5
group 2
crypto isakmp key (KEY) address (PEER IP)
crypto map map 1 ipsec-isakmp
set peer 209.*.*.230
match address 101
interface Ethernet0
ip address (IP) 255.255.255.240
ip nat outside
half-duplex
crypto map map
ip address 192.168.230.52 255.255.255.0
ip nat inside
speed auto
ip nat inside source route-map nat interface Ethernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 (GATEWAY)
no ip http server
a
access-list 101 permit ip host 192.168.230.21 host (remote ip 1)
access-list 101 permit ip host 192.168.230.21 host (remote ip 2)
access-list 101 permit ip host 192.168.230.21 host (remote ip 3)
access-list 101 permit ip host 192.168.230.21 host (remote ip 4)
access-list 111 permit ip any host (remote ip 1)
access-list 111 permit ip any host (remote ip 2)
access-list 111 permit ip any host (remote ip 3)
access-list 111 permit ip any host (remote ip 4)
route-map nat permit 10
match ip address 111
line con 0
line aux 0
line vty 0 4
password ***
login
end
Green
I think it should be route-map nonat
Community Member
Im sorry, i did it wrong it did solve my issue. thank you
102
