Issue with ASA VPN and NAT configuration
Hi I have a ASA that I'm trying to setup a VPN for roaming clients on and have them access the network. Right now I get issues with No translation group found and no matter what I do it doesn't seem to fix the problem. Attached is my current config if anyone thinks they can help.
Green
Re: Issue with ASA VPN and NAT configuration
access-list nonat permit ip 192.168.101.0 255.255.255.0 192.168.102.0 255.255.255.0
nat (inside) 0 access-list nonat
Thanks, that's what I thought. I thought I had tried that and it turns out that its mostly an issue with the default route on the server I was attempting to connect to.
However while it works I still have the errors appearing in the ASDM log except they have the clients internal ip (it is behind a NAT device) and then the destination. It appears to work fine however so I'm not sure if those are important?
Green
Why don't you post one of the logs?
110
