Community Member
Issue with Cisco NAC Agent ver:
Hello All,
For some reason I have to terminate the NAC Agent process to excute some tasks then reopen it again using a CMD batch..
the problem is everything works fine but when it comes to the part of re-executing the NAC Agent it works but the CMD stops performing the next tasks in the batch file..very strange and I believe that this problem is related to the NAC Agent as I tried to open many programs the same way without any problem also I tried the batch on some PCs with the same error.
I am using Windows XP-SP3
NAC Agent ver:
((My batch file is attached..I made it to fix the problem of the Login POP Up window that doesn't appear automatically)).
