05-06-2010 08:47 PM - edited 02-21-2020 03:57 AM
During my Demo of the NAC solution I'm having a hard time with NAC's AD SSO. I have already added the AD on the server and the status is "STARTED" but when i logged on to the machine it doesn't perform SSO. I have checked that the CAS is not listening to PORT 8910 although I have allowed the required TCP and UDP ports. What could be the problem with this?
Vanessa Joy Zamora
05-06-2010 08:51 PM
Hi Guys,
In addition I'm using NAC 4.7.2 for the test machine I'm using Winows 7 OS.
05-11-2010 03:22 PM
Vanessa,
CAS should be listening on 8910. If it's not then somethings not right.
Please post your CAS logs here for review. Also what sort of AD are you authenticating against? (2k3/2k8/2k)?
Faisal
05-11-2010 10:42 PM
05-12-2010 07:07 PM
Vanessa,
You didn't answer what your AD is. Also what version of CCA are you running? Windows 7 required 4.7.x of CCA.
HTH,
Faisal
05-12-2010 07:27 PM
Hi Faisal,
The AD that we are using is Windows Server 2003 and the NAC version is 4.7.2.
Vanessa
05-12-2010 08:05 PM
Vanessa,
Okay. How did you run the ktpass command on your AD for the user that you're using for the CAS AD SSO setup?
Do you have the output saved from that ktpass run? Also can you verify what version of ktpass did you use?
Faisal
