L2L connection between Checkpoint NG and Cisco 3000 VPN concentrator
I get an error notice when trying to create connection. IKE phase1 goes OK but phase 2 gives error notice ' Received non-routine Notify message: Invalid ID info (18) '. Does someone know what can be wrong? I'am using 3DES - MD5 .
Re: L2L connection between Checkpoint NG and Cisco 3000 VPN conc
I faced similar problem, check the network list & routing table on both ends
Bronze
What feature pack are you using. I had a similar issue as well with FP2, and could never get it past phase2. I gave up thinking it was the CP firewall
-Chris
To resolve this issue 'Support key exchange for subnets' must be disabled in the VPN Advanced tab of the Interoperable Device object.
Let me know if it works
I am having the same issue. When I turn off Support for subnets I get a new error on the Checkpoint side: no subnet support in ike negotiations. Is there something that needs to be changed on the cisco side to make it work?
having same problem, has anybody delt with this?
285
