Community Member
L2L Connection issue between 3000 and 3030
Theres 3030 v 3.6.4 mine 4.0.1
requirments no nat on their side. Nat on my side.
IKE Auth. mode: Pre-shared Key
IKE Preshared Key: generated
IKE Auth. algorithm: MD5/HMAC-128
IKE Diffie-Hellman: Group 2 (1024 bits)
IKE Encryption: 3DES-168
IKE Neg. mode: Main
IPSec Authentication: MD5/HMAC-128
IPSec Encryption: 3DES-168
IPSec Encapsulation: ESP Tunnel
Setup only works when L2L is connection type is orinate and then it only works for 30s and drops but comes right back
error is:
24114 10/17/2006 11:18:35.420 SEV=4 IKEDBG/0 RPT=258
QM FSM error (P2 struct &0x3b7dc44, mess id 0x916f2e45)!
24115 10/17/2006 11:18:35.430 SEV=5 IKE/194 RPT=2313 xx.x.x.xx
Group [L2L: XXXX]
Sending IKE Delete With Reason message: No Reason Provided.
When I change the connection type to Bi-Direction I get nothing.
Any help greatly appreciated
Re: L2L Connection issue between 3000 and 3030
QM FSM Error = Quick Mode Finite State Machine Error.
In general, a state machine is any device that stores the status of something at a given time and can operate on input to change the status and/or cause an action or output to take place for any given change. The Quick Mode IKE engine on a 3000, or any other device, is basically an example of a state machine and each variable input changes one or more states and may cause other actions to take place. And each software/hardware routine that runs begins with some initial state that may change as it begins to handle input. Thus, at any moment in time, the system can be seen as a very complex set of states and each
program in it as a state machine.
