L2L Connects for max of 15minutes then drops. Errors.
I need some help all. I have several L2L sites configured the same way and they all work perfectly except for this one. Any insight would be GREATLY, GREATLY appreciated. I'm banging my head against the wall. Below is some log info...
34629 12/11/1553 05:28:14.120 SEV=5 IKE/34 RPT=2420 155.255.61.33
Received local IP Proxy Subnet data in ID Payload:
Address 10.23.0.0, Mask 255.255.0.0, Protocol 0, Port 0
34631 12/11/1553 05:28:14.120 SEV=4 IKE/61 RPT=1978 155.255.61.33
Group [155.255.61.33]
Tunnel rejected: Policy not found for Src:155.255.61.33, Dst: 10.23.0.0!
34633 12/11/1553 05:28:14.120 SEV=4 IKEDBG/0 RPT=2199
QM FSM error (P2 struct &0x7fa3f98, mess id 0x9cc3d4d9)!
34634 12/11/1553 05:28:14.120 SEV=4 IKEDBG/65 RPT=2377 155.255.61.33
IKE QM Responder FSM error history (struct &0x7fa3f98)
<state>, <event>:
QM_DONE, EV_ERROR
QM_BLD_MSG2, EV_NEGO_SA
QM_BLD_MSG2, EV_IS_REKEY
QM_BLD_MSG2, EV_CONFIRM_SA
34639 12/11/1553 05:28:24.110 SEV=5 IKE/50 RPT=678 155.255.61.33
Connection terminated for peer 155.255.61.33 (Peer Terminate)
Remote Proxy N/A, Local Proxy N/A
34642 12/11/1553 05:28:24.140 SEV=4 AUTH/23 RPT=688 155.255.61.33
User [155.255.61.33] Group [155.255.61.33] disconnected: duration: 0:29:13
34643 12/11/1553 05:28:31.660 SEV=4 IKE/119 RPT=729 155.255.61.33
PHASE 1 COMPLETED
34644 12/11/1553 05:28:31.660 SEV=4 AUTH/22 RPT=691
User [155.255.61.33] Group [155.255.61.33] connected
34645 12/11/1553 05:28:31.900 SEV=5 IKE/35 RPT=465 155.255.61.33
Received remote IP Proxy Subnet data in ID Payload:
Address 10.2.136.0, Mask 255.255.248.0, Protocol 0, Port 0
34648 12/11/1553 05:28:31.900 SEV=5 IKE/34 RPT=2421 155.255.61.33
34651 12/11/1553 05:28:31.900 SEV=5 IKE/66 RPT=444 155.255.61.33
IKE Remote Peer configured for SA: L2L: Brazil
34652 12/11/1553 05:28:32.240 SEV=4 IKE/49 RPT=5015 155.255.61.33
Security negotiation complete for LAN-to-LAN Group (155.255.61.33)
Responder, Inbound SPI = 0x5afc4ac6, Outbound SPI = 0xdb9c5462
34655 12/11/1553 05:28:32.250 SEV=4 IKE/120 RPT=5015 155.255.61.33
PHASE 2 COMPLETED (msgid=e8ba0e65)
34656 12/11/1553 05:28:44.150 SEV=5 IKE/50 RPT=679 155.255.61.33
34659 12/11/1553 05:28:44.160 SEV=4 AUTH/23 RPT=689 155.255.61.33
User [155.255.61.33] Group [155.255.61.33] disconnected: duration: 0:00:12
1 REPLY
Re: L2L Connects for max of 15minutes then drops. Errors.
I guess you need to upgrade the OS
171
