LAN disconnects while connecting to PPTP session
Iam trying to connect to customer server thro PPTP.
While PPTP session connects my LAN services disconnets.
Is there any workaround to use both simultaneously.
1 ACCEPTED SOLUTION
Re: LAN disconnects while connecting to PPTP session
Hi.
Inside the "TCP IP Options, Advanced" of your MS PPTP Connection (on the client) you can find a possibility to disable default routing over the PPTP Connection. The option calls "Use default-gateway for remote network". If disabled it should not drop while dialing.
Did it help?
Nice day Patrik
Any body has any suggestions?
Hi.
Did it help?
Nice day Patrik
But when i try to connect to servers thro' RDC iam unable to connect and DNS does not resolve
148
