LAN-to-LAN Dynamic VPN between PIX515E and BeWAN 6004
I'm trying to establish a VPN tunnel in dynamic mode between a PIX515E rel 6.3(1) and a BeWAN 6004. I need dynamic mode because the BeWAN is connected to a provider that is delivering his IP address when coming on line via the ADSL line.
The ISAKMP stucks in this state : MM_KEY_EXCH
I've seen the message : ISAKMP: reserved not zero on payload 5!
This usually indicates a problem with the key, but i've re-created a new key on both sides and rebooted the boxes.
I have tried a static configuration by watching the attributed IP address of the BeWAN and in this case it works !
Here is a sample debug ouput taken from the PIX in dynamic mode :
crypto_isakmp_process_block:src:62.62.228.16, dest:195.146.210.26 spt:500 dpt:500
OAK_MM exchange
ISAKMP (0): processing SA payload. message ID = 0
ISAKMP (0): Checking ISAKMP transform 0 against priority 20 policy
ISAKMP: life type in seconds
ISAKMP: life duration (basic) of 28800
ISAKMP: encryption DES-CBC
ISAKMP: hash MD5
ISAKMP: auth pre-share
ISAKMP: default group 1
ISAKMP (0): atts are not acceptable. Next payload is 3
ISAKMP (0): Checking ISAKMP transform 1 against priority 20 policy
ISAKMP: hash SHA
ISAKMP (0): Checking ISAKMP transform 2 against priority 20 policy
ISAKMP: encryption 3DES-CBC
ISAKMP: hash MD5
ISAKMP (0): Checking ISAKMP transform 3 against priority 20 policy
ISAKMP: hash MD5
ISAKMP: default group 2
ISAKMP (0): atts are acceptable. Next payload is 0
ISAKMP (0): SA is doing pre-shared key authentication using id type ID_FQDN
return status is IKMP_NO_ERROR
OAK_MM exchange
ISAKMP (0): processing KE payload. message ID = 0
ISAKMP (0): processing NONCE payload. message ID = 0
PIX-CHWIS(config)# sh crypto isa sa
Total : 1
Embryonic : 1
dst src state pending created
195.146.210.26 62.62.228.16 MM_KEY_EXCH 0 0
Has anybody an idea ? Will it work in dynamic mode ?
Re: LAN-to-LAN Dynamic VPN between PIX515E and BeWAN 6004
Should work in dynamic mode. You're correct in stating that the "reserved not zero on payload" usually means the ISAKMP key is wrong, or at least they differ on both sides. For dynamic mode you'll have a line in your config something like:
> isakmp key address 0.0.0.0
so make sure this is the key that you're changing. Other than that, can you post the config (xxxx out your passwords and IP addresses), maybe there's something in there. Can you get any debugs from the other side?
I've changed the right key.
I haven't debugs from the other side, but here's the config :
PIX-CHWIS# sh run
: Saved
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto shutdown
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 intf2 security4
enable password xxxxxxxx encrypted
passwd xxxxxxx encrypted
hostname PIX-CHWIS
domain-name chwis.ch
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
access-list compiled
access-list inside_access_in permit tcp host 192.42.172.117 host 195.146.194.238 eq smtp
access-list inside_access_in permit tcp host 192.42.172.118 host 195.146.194.238 eq smtp
access-list inside_access_in permit tcp host 192.42.172.117 host 195.146.194.38 eq pop3
access-list inside_access_in permit tcp host 192.42.172.118 host 195.146.194.38 eq pop3
access-list inside_access_in deny udp any any eq 7070
access-list inside_access_in deny tcp any any eq 554
access-list inside_access_in deny tcp any any eq 1755
access-list inside_access_in deny udp any any eq 1755
access-list inside_access_in permit ip host 192.42.172.20 10.25.0.0 255.255.0.0
access-list inside_access_in deny ip host 192.42.172.20 any
access-list inside_access_in deny ip host 192.42.172.51 any
access-list inside_access_in permit ip host 192.42.172.60 10.25.0.0 255.255.0.0
access-list inside_access_in deny ip host 192.42.172.60 any
access-list inside_access_in deny ip host 192.42.172.70 any
access-list inside_access_in permit ip host 192.42.172.90 10.25.0.0 255.255.0.0
access-list inside_access_in deny ip host 192.42.172.90 any
access-list inside_access_in deny ip host 192.42.172.100 any
access-list inside_access_in deny ip host 192.42.172.117 any
access-list inside_access_in deny ip host 192.42.172.118 any
access-list inside_access_in permit ip host 192.42.172.120 10.25.0.0 255.255.0.0
access-list inside_access_in deny ip host 192.42.172.120 any
access-list inside_access_in permit ip 192.42.172.0 255.255.255.0 any
access-list inside_outbound_nat0_acl permit ip 192.42.172.0 255.255.255.0 10.25.0.0 255.255.0.0
access-list outside_cryptomap_20 permit ip 192.42.172.0 255.255.255.0 10.25.0.0 255.255.0.0
access-list outside_access_in deny ip any any
pager lines 24
logging on
logging console warnings
logging buffered warnings
logging trap notifications
mtu outside 1500
mtu inside 1500
mtu intf2 1500
ip address outside w.x.y.z 255.255.255.252
ip address inside 192.42.172.245 255.255.255.0
no ip address intf2
ip verify reverse-path interface outside
ip verify reverse-path interface inside
ip audit info action alarm
ip audit attack action alarm
pdm location 192.42.172.127 255.255.255.255 inside
pdm location 192.42.172.240 255.255.255.255 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 192.42.172.0 255.255.255.0 0 0
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 y.z.w.x 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
aaa authentication http console LOCAL
aaa authentication telnet console LOCAL
ntp server 134.214.100.6 source outside
http server enable
http 192.42.172.240 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community chwis
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map RETRAITE 1 set transform-set ESP-3DES-MD5
crypto map dynmap 20 ipsec-isakmp dynamic RETRAITE
crypto map dynmap interface outside
isakmp enable outside
isakmp key ******** address 0.0.0.0 netmask 0.0.0.0
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 28800
telnet 192.42.172.240 255.255.255.255 inside
telnet timeout 5
ssh timeout 5
console timeout 30
username yyyyyyyyyy password xxxxxxxx encrypted privilege 15
terminal width 80
Cryptochecksum:220a5e4e8ca2dde6ce83062a0b0cfc25
: end
PIX-CHWIS#
206
