Lan-to-LAN tunnel (IOS - VPN 3000) ICMP problem.
I have configured a LAN to LAN tunnel between and 3005 and an 837 ADSL router. The tunnel works fine for tcp/udp applications but I cannot ping between the remote site and the central office (initiating from either end). The icmp echo packet is denied by the access list on the public interface of the 837. I don;t know why this is as it comes through the encrypted tunnel. Ping works fine IF I remove the "ip nat outside" statement from the interface dialer0 (as below)??
Any pointers?
Config as follows:
version 12.3
no service pad
service password-encryption
hostname cj-192.168.150.1
boot-start-marker
boot-end-marker
logging buffered 16384 debugging
no logging console
enable secret 5 xxx
username xxxx password 7 xxxx
clock timezone GMT 0
clock summer-time BST recurring last Sun Mar 1:00 last Sun Oct 1:00
no aaa new-model
ip subnet-zero
no ip source-route
no ip icmp rate-limit unreachable
ip tcp path-mtu-discovery
no ip domain lookup
ip domain name xxx
ip host helsinki xxx
ip host vpn3005 xxx
ip host publicip xxx
no ip bootp server
ip inspect name fwout cuseeme
ip inspect name fwout ftp
ip inspect name fwout http
ip inspect name fwout skinny
ip inspect name fwout tcp
ip inspect name fwout udp
ip inspect name fwout vdolive
ip inspect name fwout fragment maximum 256 timeout 1
ip inspect name fwout h323
ip inspect name fwout netshow
ip inspect name fwout icmp
ip inspect name fwout realaudio
ip inspect name fwout smtp
ip inspect name fwout sqlnet
ip inspect name fwout streamworks
ip inspect name fwout rcmd
ip inspect name fwout rtsp
ip audit notify log
ip audit po max-events 100
ip ssh time-out 60
ip ssh authentication-retries 2
no ftp-server write-enable
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key xxxx address xxxx
crypto ipsec transform-set office-set esp-3des esp-sha-hmac
crypto map office-map 10 ipsec-isakmp
set peer xxxx
set security-association lifetime kilobytes 10000
set security-association lifetime seconds 28800
set transform-set office-set
set pfs group2
match address TO-OFFICE
interface Ethernet0
ip address 192.168.150.1 255.255.255.252
ip access-group OUTBOUND in
no ip redirects
no ip proxy-arp
ip nat inside
ip inspect fwout in
no ip route-cache
no ip mroute-cache
no cdp enable
hold-queue 100 out
interface ATM0
no ip address
atm vc-per-vp 256
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface Dialer0
ip address negotiated
ip access-group INBOUND in
no ip redirects
no ip proxy-arp
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer string 37
ppp chap hostname xxxxxxxx
ppp chap password 7 xxxxxxx
ip nat inside source list NONAT interface Dialer0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
ip access-list extended INBOUND
permit esp host xxxx host xxxx
permit udp host xxxx eq isakmp host xxxx eq isakmp
permit tcp host xxxx host xxxx eq 22 log
permit tcp host xxxx host xxxx eq telnet log
permit icmp any host xxxx echo-reply
permit icmp any host xxxx unreachable
permit icmp any host xxxx ttl-exceeded
permit icmp any host xxxx source-quench
permit udp host xxxx eq ntp host xxxx eq ntp
deny ip any any log
ip access-list extended NONAT
deny ip 192.168.150.0 0.0.1.255 10.0.0.0 0.0.0.255
permit ip 192.168.150.0 0.0.1.255 any
deny ip any any
ip access-list extended OUTBOUND
deny ip any any
ip access-list extended TO-OFFICE
permit ip 192.168.150.0 0.0.0.3 10.0.0.0 0.0.0.255
access-list 1 permit xxxx
access-list 2 permit 137.33.0.0 0.0.255.255
no cdp run
control-plane
line con 0
no modem enable
transport preferred all
transport output all
stopbits 1
line aux 0
stopbits 1
line vty 0 4
access-class 1 in
login local
transport input telnet ssh
scheduler max-task-time 5000
sntp server xxxx
sntp server xxxx
end
Thanks in advance.
Re: Lan-to-LAN tunnel (IOS - VPN 3000) ICMP problem.
I have done some more testing and having removed NAT completly I still get the same problem. Packets are decrypted but are denied by the INBOUND acl. I have since added statements for the LAN to LAN private traffic to the INBOUND acl and it works ok now.
access-list INBOUND permit ip
Is this correct? Why isn't traffic that comes through the tunnel allowed to bypass the acl?
Answering my own problem here!
Yes it is correct
See bug id CSCdz54626
154
