10-07-2002 08:05 AM - edited 03-09-2019 12:34 AM
I need to connect my network to another businesses network via a Lan to Lan tunnel using a VPN Concentrator to PIX mainly for FTP purposes. Well, theres no problem connecting the tunnel, but the problem is that the network I am connecting to has the same internal (Private) addresses as I do - 10.1.1.0. Im under the impression that this wont work due to routing issues, and even if it did, severe ugliness will occur on both ends if I try to do this. What are my options other than one of us changing our address scheme, which of course neither of us really wants to do. Thanks in advance for any replies.
10-07-2002 09:15 AM
Hi, see if this document can help you out....
http://www.cisco.com/warp/public/707/vpn_pix_private.html
Hope that helps
10-07-2002 10:55 AM
Thanks Mike, I think thats just what I needed. I appreciate your quick response.
10-14-2002 06:30 PM
FYI.
The VPN 3000 in Release 3.6 supports NAT over LAN-to-LAN for Overlapping networks.
Nelson
