11-18-2003 12:26 AM - edited 02-21-2020 12:52 PM
I have a VPN connection between two PIX' and it works very fine. Now I tried to make some outbound filter for one of the PIX' and my VPN traffic between the PIX' stops.
I thought that any traffic in the tunnel allways went through but I may have missed something.
Anyone who can help me?
My configuration is basic and made with PDM 3.01.
Software at the PIX is 6.3(3) I also uses PDM to make my filters.
Kim
Solved! Go to Solution.
11-18-2003 01:43 AM
Hi Kim,
Are you sure that you are not filtering any vpn protocol that is necessary for vpn connection to be established? can you send your config?
11-18-2003 01:43 AM
Hi Kim,
11-18-2003 02:59 AM
Thank you. You have solved my problem.
Kim
