LAN to LAN VPN
Can LAN to LAN VPN be possible by having a PIX 510 at the corporate office and other branches let say
Branch 1 has 1720 router with T1 Circuit
Branch 2 has VPN concentrator with T1 circuit
Branch 3 has PIX with DSL Circuit
Branch 4 has Router with DSL Circuit
or all the branches should have the PIX as well in order to do LAN-to-LAN VPN.
Re: LAN to LAN VPN
What kind of pix? No, the other sites dont need to have a pix at there location in order to do vpn. Most IOS routers can do vpn as well, you'll just need to get the software on them in order to do so.
Kurtis
Re: LAN to LAN VPN
It is PIX 510. Can PIX 510 run VPN or I will have to have PIX 515/520/525.
Re: LAN to LAN VPN
as long as when you do show ver, it either shows des or 3des feature, then you can do vpn with it.
100
