Lan2lan to disconnect when idle for 8hrs
We have a 3015 concentrator that has Lan to Lan with a partner. Is there a way to disconnect connection when there is no activity going on. Is it the Lifetime setting s.There are 2 lifetime settings which one do I use?
1 REPLY
Silver
Re: Lan2lan to disconnect when idle for 8hrs
THe two lifetime settings should be data and time (in seconds). That said, if the tunnels are still active, it is because there is some data being sent through them, and then they will stay up. Basically, there is activity going on, because if there were not, eventually the tunnel would be taken down
87
