Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Large Scale DMVPN
I am in the design phase of a large scale deployment of DMVPN and I would like some info from anyone that is currently using this technology. We will have somewhere around 800 DMVPN endpoints when we are done. 90% of the endpoints will be 871 routers. I would like to know what should we use for the head end router and how many sessions will that router hold. I find documents that the 7200/7600 will hold only 200 sessions. I don't see how that could be the largest device Cisco makes. Will the 3845 hold that many?
I know Cisco uses this so I would assume they have at least 800 endpoints. What does Cisco use.
Thanks for your help
1 REPLY
Re: Large Scale DMVPN
hi
As per the datasheet it can support upto Up to 2500 VPN tunnels but not sure about the simultaneous sessions it can support.
http://cisco.com/en/US/products/ps5855/index.html
regds
139
