LinkSys BEFVP41 calling a C1751: Problem...
Have a look at this portion of a debug. Phase-1 will not negotiate. Any general pointers?? IPs are altered for security, but *are* routable on the internet.
__________________________________________________
18:55:33: ISAKMP (0:1): Checking ISAKMP transform 1 against priority 3 policy
18:55:33: ISAKMP: encryption DES-CBC
18:55:33: ISAKMP: hash SHA
18:55:33: ISAKMP: auth pre-share
18:55:33: ISAKMP: default group 1
18:55:33: ISAKMP: life type in seconds
18:55:33: ISAKMP: life duration (VPI) of 0x0 0x0 0x70 0x80
18:55:33: ISAKMP (0:1): atts are acceptable. Next payload is 3
18:55:33: CryptoEngine0: generate alg parameter
18:55:33: CryptoEngine0: CRYPTO_ISA_DH_CREATE(hw)(ipsec)
18:55:33: CRYPTO_ENGINE: Dh phase 1 status: 0
18:55:33: ISAKMP (0:1): Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
Old State = IKE_R_MM1 New State = IKE_R_MM1
18:55:33: ISAKMP (0:1): sending packet to 10.10.10.10 (R) MM_SA_SETUP
18:55:33: ISAKMP (0:1): Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
Old State = IKE_R_MM1 New State = IKE_R_MM2
18:55:43: ISAKMP (0:1): retransmitting phase 1 MM_SA_SETUP...
18:55:43: ISAKMP (0:1): incrementing error counter on sa: retransmit phase 1
18:55:43: ISAKMP (0:1): sending packet to 10.10.10.10 (R) MM_SA_SETUP
1 REPLY
Re: LinkSys BEFVP41 calling a C1751: Problem...
This doesn't tell us a whole lot. The ISAKMP parameters are correct, going by the "atts are acceptable" statement. The router then sends a reply packet back to the LinkSys but gets no response to it, it then retransmits it 10 seconds later, still no response, etc.
Can you check the LinkSys log files and see what it's saying, this debug doesn't give us enough info other than the LinkSys doesn't reply to us. You might want to check any access-lists or filtering, it could be that the LinkSys doesn't receive our reply, so it never sends another packet.
146
