Linksys Wireless and VPN
I have a Linksys WUSB11 2.6 802.11b on my laptop. I can use my laptop and connect to the VPN at work with no problem using my cable modem and a direct connection to my network switch. However, when I try to use the WAP11 Access Hub (it is not a router) and this USB with VPN, I get connected but all the packets are discarded. The Wireless works fine except for the VPN.
Any Ideas?
1 REPLY
Re: Linksys Wireless and VPN
You need to go VPN client - Set MTU size and set the MTU for the wireless card to 1400. It will need a restart. This then means the is enough size for the IPSEC headers and all should work OK.
109
