Linux 3.6.2 (A) to PIX 515 problem
Okay. So I'm in a bit of a bind.
Trying to get the Linux 3.6.2 (A) client to connect to our PIX 515, running 6.2(2) code, without the 3DES option.
Client platform is RedHat Linux 8.0. Compile worked fine.
Windows XP/2000 clients work fine. But the Linux client returns a "The VPN sub-system is busy or has failed." error after "Negotiating security policies."
Any thoughts?
Thanks in advance.
  • Other Security Subjects
1 REPLY
Bronze
Re: Linux 3.6.2 (A) to PIX 515 problem
You should check out the suggestion given in the below FAQ
http://www.cisco.com/warp/public/471/vpn_3000_faq.shtml#Q64
90
