Community Member
LMS 3.0 ANI and rmeng TCP & UDP Ports
Does anyone know the TCP or UDP ports to connect to the ANI (Campus Mgr) and rmeng (RME) databases?. I am trying to connect (retreive) info from the databases .. but I cannot find the TCP ports.
P.S. Yes I know Cisco does not like it when any external connection is made:-)) and I know abt the dbreader.
Bronze
Re: LMS 3.0 ANI and rmeng TCP & UDP Ports
Cisco works uses following ports:
CiscoWorks runs on port 1741
42340/tcp CW2k Deamon Manager (server processes)
42341/tcp Open Server Gateway
42343/udp Osagent
42343/tcp Jrun
1741/tcp Port used for CW2K HTTP Server; used when accessing CiscoWorks
If some other port is desired for communication with the Cisco works server you can modify the httpd.conf file. After changing the port you will need to stop and start the daemon manager service.
Community Member
Thanks. I had posted this question in the Security Section by mistake and could not move it. I reposted in Network Mgmt and got my answer.
Thanks anyway for the port info.
176
