Lock And Key problem
I am trying to use the lock&key feature on a 2811 router applying the following configuration:
interface fast0/1
ip access-group 101 in
interface vlan2
access-list 101 permit tcp any host 195.X.X.X eq telnet
access-list 101 dynamic acceso_kalisto permit ip any any
line vty 0 15
autocommand access-enable host timeout 20
exit
username xxx password xxx
Altough I have only applied the ACL on 2 interfaces (FastEthernet0/1 and VLAN2), when I try to telnet the router from another interface (FastEthernet0/0) I get this error message:
% No input access group defined for FastEthernet0/0.
Am I forced to apply an ACL on ALL of the router interfaces for Lock&Key to work? why ?
Thanks in advance.
1 REPLY
Re: Lock And Key problem
As you may know, lock-and-key creates dynamic ACE once the user is authenticated by the router on telneting into it. If there's no ACL applied on F0/0 then there's no need for this feature enabled at all as all traffic is allowed through this interface. You don't need to apply the ACL on all the interfaces but apply on the interfaces that you want to allow the user traffic to traverse only on successful authentication.
Sundar
326
