Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Logging on to Inside network from DMZ zone
Running cisco pix 515 what would I need to put into the config to allow access from the perimeter (dmz) machines ip of 10.1.0.? subnet 255.255.255.240 to inside network of 10.0.0.? subnet 255.255.0.0 ?
1 REPLY
Re: Logging on to Inside network from DMZ zone
Without looking at the rest of your config, here’s probably what you need:
static (inside,dmz) 10.0.0.0 10.0.0.0
netmask 255.255.0.0
conduit permit tcp 10.0.0.0
255.255.0.0 any any 10.1.0.0
255.255.0.240
Or you can be more specific with your conduit(s) if you know which protocols and ports you wish to allow. Be as specific as you can.
82
