Logging
Hi.
We have a very interesting problem. Using KIWI as a syslog server, we are trying to record each and every time a user logs into a pix or asa device and ALSO every command entered. Is this possible via programming on the security device OR MUST it be done on syslog???
Thanks!
1 ACCEPTED SOLUTION
Re: Logging
Hi Net,
Please mark this thread as resolved so other can benefit.
~JG
Re: Logging
These are standard in-built features of a TACACS service. If this is an option for you it will be far easier than trying to bend the syslog features do it
Re: Logging
Thank u so much.
Would u know of a freeware tacacs+ prod? We don't have cworks. :(
Cheers.
Re: Logging
Also, is there any way to record the show commands somebody enters as well..
Re: Logging
With tacacs you can log all commands entered by users. You can download the eval ver using your CCO id.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/acs40/user/r.htm#wp550550
~JG
Re: Logging
Yes, all commands entered are logged. You can get quite complex with login authentication and permissions too.
I have good success with tacplus from shrubbery.net if you're willing to get your hands a little dirty compiling in *nix http://shrubbery.net/tac_plus
If you're talking pure MSWin world, I have no idea sorry
Re: Logging
Thank you so much! This definitely helps!
Re: Logging
Hi Net,
~JG
120
