CSM 3.0.1 SP1 on Windows 2003 SP2
I can login to the web CSM suite website (homepage), but cannot login using the same credentials using the CSM client.
This occurs after a reinstallation to attempt to resolve the problem below.
On a second CSM installation, I cannot login using the CSM client, which gives the following error:
"CMF session id cannot be assigned. Please confirm the server is running.". All services appear to be running and logfiles (all that I can find) indicate that the server is up.
The client logs show "SEVERE: Fail to connect to server xxx.xxx.xxx.xxx: 302".
Attempting to login to the web session on this server fails after attempting to load the page (which eventually times out after about 5 minutes).
