Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Looking for example config help
I am trying to get a PIX 506 (6.22) connected via a cable modem with a dynamic IP address to do a site to site VPN with a PIX 520 (6.22) with a static IP. The 520 also has two other Site to Site VPN's terminateing on it useing static IP's on each end. I had no problems getting the vpn's up on the static ip's, but nothing I seem to do works to get the dynamic to static running.
Could someone share a working dynamic to static config snippit for both sides of the VPN?
Miles
1 REPLY
Re: Looking for example config help
Below you will find a sample config for Dynamic to Static IPSec:
http://www.cisco.com/warp/public/110/dynamicpix.html
Arul
87
