lost connection to sensor
Hello all,
i have a situation where the cspm is no longer communication with the one of two ids sensors. The version of the sensor is 3.0(6) and the cspm version is 2.3.3i
When logged into the sensor and i type "sho config", it shows
Sensor application status:
nr.postofficed not running
nr.fileXferd not running
nr.sapd not running
nr.packetd not running
Is there a way to restart these?
any help is sincerely appreciated
thanks
1 REPLY
Re: lost connection to sensor
The best method is to simply reboot your sensor.
A reboot should start these processes up automatically.
If they are still not running after the reboot (or go back to not running at a later time) then contact the TAC for assistance. You will need to troubleshoot what is happening on your sensor.
84
