Low level reset.
I have heard that you can do a low level reset or something on a Cisco concentrator 3000. We have had a lot of strange problem with this device, we deleted the config file, but it doesn’t fix the problem. Is it possible to do total file system reset?
1 ACCEPTED SOLUTION
Re: Low level reset.
In routers normally we use the passwd recovery procedure to bring that to default state.
but in concentrator i think u can use up the 7th option mentioned in the below link to load without any config file..
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_configuration_example09186a008014c1ba.shtml
regds
regds
Thanks,,
Problem solved.
113
