Low speed on Cisco-Remote-VPN
i have problems with an Cisco-VPN-Client connection to an Cisco 1721 router.
The VPN is normally working very fine, but one (1) person/laptop has such a low speed that working is impossible.
Moving in the file-sharing from one directory to another takes minutes.
I dont have any idea where i should start. Some ideas?
Re: Low speed on Cisco-Remote-VPN
Hi Chris
There are lots of parameter to consider here for the reason for slowness.
You need to check the OS being used in the client laptop and the vpn client version being used also the connectivity being used to acess the vpn server ..
regs
What version of the Client-Software should I use?
The PIX is Ver. 6.3
110
